remotely use SW
remotely use SW
remotely use SW
Anyone use solidworks remotely like through remote desktop go to my pc etc?  Just seeing if it's feasible to work from home once and awhile.  My home PC is not beafy enough to run our assemblies and we keep our database of parts on our server.  We don't use any pdm software.
Certified SolidWorks Associate
SW2009 X64 SP 1.0
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
RE: remotely use SW
yes i do! I am running into the same situation as you are since I do alot of field work. two things that you have becareful of are the graphics won't be nice, and laggy  performance due to slow internet speed.
RE: remotely use SW
Ya I figure it would be laggy but hopefully still doable.  We did some tests here in the office and it wasn't to bad.  Will try at home with PC Anywhere.  Remote desktop didn't work wouldn't refresh the screen fast enough.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: remotely use SW
windows RTM is slow because it never use image compression and it is not reliable at all.... but working remotely is perfectly fine as long as you are not doing any rendering work.
RE: remotely use SW
Try TeamViewer or LogMeIn
RE: remotely use SW
Our IT guy mentioned teamviewer.  Will try PCanywhere to see how it goes and go from there.
Thanks all.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
RE: remotely use SW
teamviewer will benefit you by bypassing all the hassle when dealing with firewall connections. it free to try anyways, good luck.
RE: remotely use SW
Couldn't get PCanywhere to connect at home.  Probably had a setting wrong.  I will talk to our IT guy next time he is in about using teamviewer.
SW2009 X64 SP 1.0
XP Pro X64 SP2.0
