ISO 2768 for linear less than 0.5mm
I have a dwg that specifies tolerances to ISO 2768mk, but has dimensions less than 0.5mm .
What tolerances to I apply to these smaller than specified dimensions?
RE: ISO 2768 for linear less than 0.5mm
"For nominal sizes below 0.5mm, the deviations shall be indicated adjacent to the relevent nominal size(s)"
I would ask the supplier of the drawing what they want applying to the dimension. It's likely they (like me) didnt realise the standard stopped at 0.5mm. Be prepared to suggest a tolerance yourself as it may be possible they have no idea what would be considered reasonable in that range.
Will Walters
Sheffield UK
Designer of machine tools - user of modified screws
As above go back to the whoever you got the drawing from.
If you can't get an answer and insist on proceeding at risk I'd just do the best you can, and make sure you at least hit the tols for medium .5-3, however I strongly discourage this.
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
