Balloon arrow heads jumping to spots?!
Apologies if this has been covered before, but it's driving me nuts!
I've had this in several different drawings (but not all). It goes like this:
- Make drawing.
- Balloon parts (amongst other things) using arrow heads on the lines as requested (I direct them to a point or line on the part)
- Complete the drawing and close it
- Open at a later date to print and the arrow heads on the balloons have jumped into spots
It's not only time consuming but annoying having to check for this every time I open a drawing to print it. Is this just another glitch, or is there a method to cure it?
- Make drawing.
RE: Balloon arrow heads jumping to spots?!
- - -Updraft
SW 2010 SP 2.0
Dell Inc. Precision WorkStation 670
4096 Meg, Quadro FX 1400
DUAL DELL 2007FP DISPLAY
Windows XP PRO SP3
CBL: The arrowheads change into filled circles. It's as if you picked up the point and moved it JUST off of the line I pointed it at, placing it in the body of the object and therefore creating a filled circle. Interestingly/weirdly, it seems to be doing this mostly with fixings such as hex head bolts...
pdelnet: That might be a simple solution - I'll try it out! Getting mark-ups back times over is getting tiring!
As so often seems to be the case with SW, I've had to compromise... settings > doc. prop's > annotations and set all attachments to arrowheads. I lose the filled circles in the body of parts, but at least I don't have to keep going back and changing things all the time.
Thanks lads.
Everytime I change it back; it resets at the next session.
I just remembered something that might help. Try selecting the drawing view, RMB to Lock View Focus before creating your balloons. I've seen a few strange things happen when notes and other things are NOT associated with a view and they really should have been. I've never had to resort to creating sketch points to snap an arrowhead to.
- - -Updraft
