Bearing pre-fill and re-lube calculation
Hi All,
I am looking for a more simple way of calculating the pre-fill and basic re-lubrication volumes of different bearings
to assist many of my clients in the understanding of correct methods.Both bearings i am now working on are in steel mills both are vertical stands so while the re-lube intervals will require upgreding i need a starting point.
The bearings now in use are A) 330662AG SKF and 260RV3701 NSK.
has any body a simple way so i can better explain to my client their requirements
Best
Robert
Best
Robert
RE: Bearing pre-fill and re-lube calculation
