Suppression And Assembly Constrains
We are currently moved to NX7.5 after many years in NX3.
We have some assemblies, where from expressions could someone suppress or not components.
This was working good in NX3 and is working well in NX7.5 still.
The problem here with assembly constraints (over 200), is that if you suppress a component the corresponding constraint will give an error, which will remain until you unsuppress the component.
Can somehow suppress those constraints automatically or do sth else?
Thank you all.
Thank you all.
RE: Suppression And Assembly Constrains
http://www
in that thread I also asked about suppressed components and constraints...
Maybe the answer for the suppressed components is using Arrangements and the constraints for those components to be arrangement specific. But still we have a lot of assemblies not created with the arrangement option.
There will still be an 'Error' status, shown as a (X) flag appended to the actual Constraint icon, but in addition there will also be a 'Warning' status, shown as a /!\, and finally an 'Info' status shown as a simple <i> flag. And if you enable the 'Info' column in the Assembly Navigator, these same symbols will be seen there as well and when you place your cursor over the symbols in this column a 'tool tip' will appear with information about what may have caused the flag to be appear. Also, since these flags are shown in a column of their own, they can be sorted by severity by simply clicking on the column header.
Note that for the next release of NX we will try to provide additional feedback as to what happened and eventually we would like to even offer 'hints' as to what your next course of action might be. Also with the new Constraint Navigator we will be able to provide even more tools to help highlight and investigate possible Constraint issues, including the ability to Group Constraints by Status which will make it very easy to isolate Constraints which have a status of 'Error', 'Warning', 'Info' and even constraints which are 'OK', that is those with NO issues whatsoever.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
But, because I like it to be clean, I've seen that the best way (in NX7.5) to avoid being confused with constraints that become red(or warning / info) is to right click on the constraint and choose arrangement specific. There you can apply in which you like to be present. But given the fact that we never used arrangements before and that we have a lot constraints this can take much time.
In NX3 the mates would simply suppress with the corresponding component.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Paranoia (Derived from the Greek words "Para"=Out and "Nous"=Mind)?
We have a big problem with the constraints and it is not a manner of just ignoring them. When the time of physical assembly comes, we need to be extra sure that all join together.
So we need to focus more that these constraints are not causing any problem to the parametrized assembly. That needs time and that decreases productivity.
So I thing that what I say are not out of mind.
Thanx.
