Screen Refresh Issues
When I am working on a large assembly and I minimize the SW window to go to my desktop for something then I maximize the SW window again, the window only comes back partially, usually the outside border then slowly the rest comes back in segments.  What typically handles this process?  Is it video card, RAM, CPU, etc?  I have verified that I have the newest VC driver as well.
Assembly info:
LAM sat to 500 parts
7109 total parts
1520 unique parts
156 top level mates
Thanks in advance for input.
Dell T3500
Intel Xeon Quad Core W3580 3.33GHz
8GB RAM PC3-10700 (667 MHz)
Nvidia Quadro FX1800
www.phoenixdyno.com
Home of the world's most accurate and repeatable dynamometers, dynamometer accessories, and data acquisition & control software.
RE: Screen Refresh Issues
Forgot to add that I am running this on a Dell 30" monitor at the highest resolution allowed.
www.phoenixdyno.com
It's probably your graphics card. Using the latest driver doesn't mean it's an approved driver. Go to: http://www.solidworks.com/sw/support/videocardtesting.html and find out which driver you need for your system/set up. If you have to change drivers, be sure to uninstall the old before installing the new.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
Also what OS are you running?  If it is Vista or Windows 7 make sure you have a Windows Aero Theme enabled on your desktop.
Control Panel\All Control Panel Items\Personalization
Anna Wood
Xeon W3680, Nvidia Quadro 4000, 12 Gb RAM, WD Velociraptor, Dell U3011 Monitor
SW2011 SP1, Windows 7 x64
http://www.solidmuse.com
http://www.phxswug.com
Hi Anna,
I plan on running XP Pro x64 as long as I can :)
www.phoenixdyno.com
Why.....  Windows 7 is far superior to Windows XP.  If you are running SW2010 and newer you need to kick XP to the curb.
Cheers,
Anna
Anna Wood
Anna said:
I have a customized theme; how do I know if is an Aero-type setup?
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
RMB in the Windows desktop and go to Personalize
Anna Wood
