Curved Column Buckling
I am using a resource to determine the buckling allowable for a curved beam under combined bending and compression, but I do not know where the resource comes from. It is a scanned copy that has been handed down from other structure's guys and I have no way to reference it.
I have attached a copy of the portion that I have in my possession. If anyone can help me locate where this is from, I would greatly appreciate it.
Thanks in advance.
Thanks in advance.
RE: Curved Column Buckling
Cheers
Greg Locock
not sure i like the hand written notes ... P is surely the applied axial load, PE is clearly the euler column load, P0 is the true column allowable
The handwritten analysis is not relevant and has nothing to do with what I am currently working on. It was inadvertently scanned in with the text.
This is a frame that is formed in the shape of a curve, not a post-buckled beam.
I have done the Euler calculation for a straight beam and am using the chart to find a knockdown factor for a curved beam of equivalent cross-section and length.
Hope that clears up what I am trying to do.
