burner flowrate
burner flowrate
Hi guys!
I've a problem. we have 4 burners installed in a process heater.
I have only the fuel oil pressure (~4,3 kg/cm2) but I don't have the flow rate.
How can I calculate the flowrate for each burner??
Thank you all!
Bye!
Thank you all!
Bye!
RE: burner flowrate
RE: burner flowrate
RE: burner flowrate
Unfortunately the flowmeter doesn't measure the right flow, thus I'm trying to measure the flow using the pressure.
I've found the heat release curve!
