Inserting Image Onto 3DSketch Plane
How do I go about inserting an image onto a 3DSketch plane? I have always been able to insert and trace over images without issue on the primary planes.
Ultimately, I would like to import and trace over multiple images of variable tunnel cross sections at specified distances on 2D planes in order to loft between the 2D cross section profiles. Thus, I will have a 3D representation of the tunnel excavation. Is this possible?
Thank you in advance for your help! I have spent several hours looking for an answer and cannot figure it out.
RE: Inserting Image Onto 3DSketch Plane
Create a 2D sketch on the plane and then insert the Picture.
Thank you for your input - it works perfectly.
