Referenced details not showing up in V8XM
Hello, I have problem with one 2D drawing. This drawing is made from 3D views that were exported using FILE/EXPORT/VISIBLE EDGES command. Original 3D is constructed using same level 1 (but renamed). When this file (.hln) is transferred into my master layout, some details are not showing up within the detached reference file. Also, going into the .hln file and doing a simple Copy and Paste into my master is giving same results. I tried to figure out what could be the setting involved in the master or the referenced file before and during the transfer. Whatever the parameter is selected, it is always the same thing that happened. Very strange and frustrated...Does someone could help? Thank you in advance.
