liftcore wall formwork alignment
i am going to work on high rise building ,as the columns i plan to use gird line to alignment but but i don't know how to alignment the
liftcore wall formwork......
i am going to use total station.
building hight is 50 stories.
RE: liftcore wall formwork alignment
set out the kickers for the core walls, once the kickers are concreted and the formwork is stood use the same co-ordinates you used for setting out the kickers to check the alignment of the top of the formwork and adjust using push-pull props bolted to the formwork and to the slab.
hope this helps.
