Interpretation of single segment feature control
i believe i have this interpretation, but i wanted to run this by all of you just to make sure i'm on solid ground.
When i think of true position i think about the formula:
True Position = 2√ Deviation in X² + Deviation in Y² and i think of this in terms of diametrical situations.
Per the attached pdf, the .010 true position to datum B doesn't appear to be a diameter.  So will this be a straight .010 plus or minus value for each side alone?
Thank you
RE: Interpretation of single segment feature control
Bottom frame is linear tolerance zone, virtually a +-.
However, isn't the bottom frame still to be refinement, so should be smaller than top.?
Also, how is slot width position controlled by a diametric zone?
Posting guidelines FAQ731-376: Eng-Tips.com Forum Policies http://eng-tips.com/market.cfm? (probably not aimed specifically at you)
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Thanks Kenat,
i thought the bottom would be +/- .010.  This is how the blue print is showing this callout (the previous attached pdf shows teh front view on top and side view on the bottom)
Datum B (which the bottom portion calls out to) actually still is a forging.  We only deal with the inside portion (Datum A).
The way i interpreted the drawing (please correct me if i'm wrong):
- the slots themselves (midpoints) need to be within +/-.0005 (tp of .001) to Datum A (which is machined here), so a straight line will go right through both slots and the center point of Datum A and be off no more than .001.
- For the bottom portion, Datum B is this forging that basically is a straight line parallel to an imaginary line created for the first true position of .001 to Datum A, or actually vice versa where the slots machined will be +/-.010 to this forging line (Datum B).
The diameter symbol merely connotes the shape of the tolerance.   Without a diameter symbol, the tolerance zone is no longer a cylinder, but rather it is planar.  So for that lower frame, think of a bandwidth of .010 which is centered around datum B.  That means the slot's center can be .005 to either side of datum B.
That said, I can't really tell what the datums are.  And it doesn't seem right to have the diameter symbol in the upper position tolerance -- it's a slot.  (Also, Kenat, I don't think the lower frame has to have a smaller tolerance value than the upper frame since they reference different datums.)
John-Paul Belanger
Geometric Learning Systems
The slot is not a circular feature, so the tolerance zone is not a cylinder, diameter symbol in the position callout is not necessary here, and the position callout for a slot indicates symmetrical relationship between feature of size.
The datum symbol B can not place it on the center of the feature, and datum symbol A put it on the feature of size will be better for this case.
SeasonLee
Just to add to this, Datum B to the Center of Datum A is suppose to be 1.000", however this is not boxed in giving it a +/-.010 tolerance.
This was throwing me off in terms of the results attained on the CMM.  With true position call outs i think i tend to see this tie into a basic dimension, giving the true position a tolerance.  But in this case the true position isn't tied into a box dimension, so this slot to Datum B can be +/-.005 to a dimension that has a tolerance of +/-.010.
Is this an accurate way of viewing this?  (e.g. the distance from Datum B to Datum A is .995 (within the .010 tolerance), the slot distance then can be .990/1.000) or if i have another part that measures 1.000, the slot distance can be .995/1.005)
