Logo disappearing from drawing templates. Why?
I've inserted a TIF into a drawing template.  It seems to occasionally disappear.  The box will be there and I can edit the size and transparency options, but no image is displayed.
Is the image part of the format or is it a lost reference to the original graphic file?
I'm using 2008.
RE: Logo disappearing from drawing templates. Why?
It should be in the sheet format, not just the template, I think, at least that is where I have put the image.
Mine seem to actually be there in the format, at least there are no properties leading back to a file.
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
Let's delve into this a bit further.
When you say it occasionally disappears, is it disappearing from the template, or from existing drawings? Have you ever been able to get it to reappear, if so how? Does Ctrl+Q ever help? Where it's invisible, it makes me think graphics issue, but more info would be needed.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
It was inserted into the format.  I can get it to reappear if I load another format and then the original.  It hasn't disappeared again.... yet.
It seems graphics related, but it occurred on two different machines (both Dell Precision laptops, but with different Nvidia cards).  It also persists when the file is reopened.
Curious, when it does not show, will it print?
Chris
SolidWorks 10 SP4.0
ctopher's home
SolidWorks Legion
It won't save in a PDF, but I didn't try printing it directly.
