Can the plane Orientation be changed on an existing part?
4
Hi all,
I have an imported part with incorrect orientation. The right side of the part is on the front plane. Is there a way to change the orientations?
I think i can do it in the import manager but i was also wondering if i could do this to parts that I started on the wrong plane without thinking.
-Kevin
RE: Can the plane Orientation be changed on an existing part?
Yes you can. You have to open the view orientation menu (hit spacebar) Place the view to have the face view in front of you and select "Face" on the orientation window then hit the second button from the top left "Update standard view" this should place the correct orientation the way you want it.
Remember that if you do this on a part with existing drawings views they will get reoriented as well.
Hope it helps
Patrick
Thats pretty cool. It only changes the names of the views though right? The Front plane remains the same.
I was wondering if there was a quick way to have everything shift to a new orientation. In my example the sketches and entities on the front plan would go to the right plane and so on. i know I can change the sketch planes one by one, but that would be slow and require a bunch of small fixes through out the part.
Delete, or better, suppress, all the existing mates and redo them the way you want. If there are no mates then the part is(f)ixed and you must float it first.
Hardie "Crashj" Johnson
SW 2010 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
If you were to change the sketch planes of child features to planar faces of parent features, that would be a step in the right direction. However, any horizontal or vertical relationships, at the very least, would probably get toasted once you were to change the sketch plane of the first feature. In the end, probably not worth the time involved as compared to following Patrick's original response.
Jeff Mirisola, CSWP
Design Manager/Senior Designer
M9 Defense
My Blog
If it's imported you could just rotate it with a move body feature.
All useful suggestions though not exactly what I'm looking for. These tips should be good in a pinch though.
1) Open the imported part
2) Create a UCS at the point where you want the Origin to be, and orient the axes to suit
3) Save as a parasolid using the Options to save the new UCS as the Output Coordinate System
4) Open the parasolid and the UCS will have been adopted as the default global origin
Very smooth. Nice solution.
CorBlimeyLimey, that is a great tip. Often I import from Mcmaster, etc., and the orientation is awkward. If I create some default import parts as you describe, with the ucs where I want it, that will fix that problem.
"tip o' the hat to you"
SW 2010 SP 4.0
PatCouture ... be aware that the orientation can be reset by anyone at anytime by selecting the Reset Standard Views option in the Orientation toolbar.
It's a good point CBL but we don't work much on each others project here so it's unlikely to happen.
Cheers
Patrick
This is why I like to name planes and views "X-Y", "Y-Z", "Z-X".  No more messing with semantics.  "A is A", as Ayn Rand would say.
