Problems with Galvanized A325 bolts
Is anyone aware of potential problems with ASTM A325 galvanized bolts? We are specifying them on a project, which is new for this company, and they are very leary of doing so. Do any of you know of typical problems with these bolts, uses that they are not good for, etc?
RE: Problems with Galvanized A325 bolts
The can only be tightened once, i.e., they can not be reused.
Best regards - Al
http://www.FerrellEngineering.com
Their practice was to torque the bolts to a much smaller value than you would in typical structural steel.
Dik
thank you for all of the comments.
Michael.
Timing has a lot to do with the outcome of a rain dance.
thanks
Bryan
RCSC A325 & A490 requirements are attached.
FYI - attached the 2009 Spec
I doubt your application is nearly as critical as most applications for machine screws.
Hg
Eng-Tips policies: FAQ731-376: Eng-Tips.com Forum Policies
