ROLLED CYC. WITH TABS BENT INWARDE
OK I'm a little embarrassed that I can not figure out how to do this so go easy on me. It seems like a pretty simple part? I tried to do one tab an add the cyc. part as a extrude to both side then do a circle pattern but it says cannot patter the base flange? I have tried adding a cutout in the cylinder then add a flange, even adding a extrude with the bend in it but still cannot get it to flatten? Here are some pics to see what what I'm trying to do.
RE: ROLLED CYC. WITH TABS BENT INWARDE
GWUBS
Yes to all of the above and you are correct.
