Bosch LapSim Tire model
thread108-265917: Race Car Development Center
cibachrome mentioned in the referenced thread a method to generate tire models for Bosch LapSim from test data. Anyone know more?
Thanks!
Henning
Thanks!
Henning
RE: Bosch LapSim Tire model
Is it allowed to post code here? Don't want to break any protocols. I've given it to the FSAE teams (via the TTC Forum) so they can fit the Calspan/TIRF FSAE tire data for simple (yet elegant) vehicle dynamics modeling suitable for choosing tire constructions and pressure for their vehicle(s). Its actually very simple to do. I also have posted there a Matlab GUI with Sliders to show how each parameter modifies the shape of the tire function (initial slope, peak value, peak location and function limit value. For most of the thousands of tires I've tested (including race slicks), its does a VERY good job. If you also have camber information, a camber sensitivity value suitable for LapSim is produced. I believe you now have to use the purchased version of LapSim in order to actually change tire properties in the model. Just changing the panel values no longer has any effect on the results. In earlier version, changing a tire changed the results.
Again, not sure how I would post code blocks or running GUI scripts, but I could give you the function and the table of contents on how to do it and which optimizer is used. If you have access to the FSAE TTC, its all there. TTC = Tire Test Consortium. The Milliken site has a link to it.
Cheers
Greg Locock
