Low Temp Pump
Low Temp Pump
I am trying to find a pump that can pump Jet A fuel that is at -55 to -60 degrees C. The pump itself will be outside the envirnmental chamber. Flow rate 500 to 3000mL/min. Jet A fuel has a Kinematic Viscosity of 13 Centistokes at -50C. Any pump manufacturer leads would be appreciated.
RE: Low Temp Pump
RE: Low Temp Pump
http://austindenholm.com/id23.htm
RE: Low Temp Pump
http://www.ebaraintl.com/
