Shrink fits
Shrink fits
We are currently reburbishing a customers gearbox not manufactured by ourselves.
The situation is we have a shaft onto which a gearwheel is shrunk on.
The trouble is that the shaft has a 1:32 taper. What I need to know is info about the torque it will be able to transmit and also, how to install the gear. I have a feeling it is oil injection but could it be forced on with hydraulic rams.
Mike
Mike
RE: Shrink fits
I remember doing those calcs once while not long out of school, I'd have to dig deep to find 'em. (but since I never throw anything away, so I'm pretty sure I'd find 'em - eventually). If no-one replies I'll search for those notes. However, as I remember they were rather straight-forward, nothing out of the ordinary, I did them without consulting anyone else, so they couldn't have been too hard....
RE: Shrink fits
Kenneth J Hueston, PEng
Principal
Sturni-Hueston Engineering Inc
Edmonton, Alberta Canada
RE: Shrink fits
RE: Shrink fits
h
766/chapter07.pdf
RE: Shrink fits
Ok here are some more details. The start of taper is 150mm dia end of taper is 146.25 dia over a distance of 123mm. There is no keyway.
Mike
RE: Shrink fits
