does astm call for impact test at -196 deg centigrade for ss fittings
please confirm whether ss fittings welded need to have impact test at -196 deg centigrade.
if so can you give code or ref standard
RE: does astm call for impact test at -196 deg centigrade for ss fittings
Not enough information to answer your question. What is the application for these fittings? There are many codes of construction (pressure vessels, piping,) that provide guidance for impact testing requirements, you need to determine which of them applies.
HOPE I AM CLEAR.
Do you have B31.3? If not, get it.
