How to move a rigid body by applying force on its reference point?
I want to do an Abaqus static standard analysis. In this analysis I should move a rigid body by applying force on its reference point. When I apply this force the analysis does not run and I get the message "too many attempts" in the first increment. I have changed the parameters of step but it does not work. I attached a simple example. In this example I wish to move the rigid body by applying the force and have contact between this rigid body and the sheet. Please consider if I move the rigid body by displacement the analysis runs and there are not any problems. The problem is about applyind the force.
Cheers,
A,
Cheers,
A,
RE: How to move a rigid body by applying force on its reference point?
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
Tara
@Fruton: you can check the attached file. by applying force on rigid body, the analysis does not continue because of rigid body motion.
