Repour footings
Repour footings
Hi, our builder poured the footings for a pair of three bedroomed two storey brick and block built houses on thursday. the trenches were 1300 and he poured 900mm of concrete but did not stake the corners out. the back left hand corner is 200mm lower than the front right hand corner and the bit in betwee tapers down from high to low.
He says it would be too time consuming to make it up with brick and block and to get around this he proposes repouring over what has already been poured, next weekend. this would be around another 300 or 400mm of concrete on top of the 900 already laid. Will this method be structurally sound or is it essential that it is all poured in one go.
any help on this would be greatly appreciated.
RE: Repour footings
Check with your local building official to see if his proposal is allowed. Get with the engineer who designed the structure. Why is your footing so thick?
RE: Repour footings
