Turbine Problem
Turbine Problem
Hello everyone.
i need you help regarding turbine test, the problem after we run the turbine (hot condition) about 1 hour, the shaft cannot rotate manually. but during cold condition the shaft is easy to rotate manually.
also if someone can give me reference for commissioning a boiler or share or tips it will be highly appreciated.
thanks in advance..
Escariote.
thanks in advance..
Escariote.
RE: Turbine Problem
RE: Turbine Problem
This is wrong - dead wrong - and you need to check with your turbine sales representative (and the turbine installation company rep)immediately.
RE: Turbine Problem
thank you for your comments. after thorough investigation and several testing, we found out that the exhaust piping during hot condition pushes the turbine so we need to install a new support to reinforce the piping.
escariote
RE: Turbine Problem
RE: Turbine Problem
rmw
RE: Turbine Problem
Cheers,
gr2vessels
RE: Turbine Problem
rmw
RE: Turbine Problem
Offshore Engineering&Design
