Releasing moment or force in local coordinate system
I have a question which is killing me. I realllllyyyyyy appreciate if you can help me.
situation and structure:
I am dealing with the structure with large movement and I am doing static and transient analysis with large displacement. I can not release the moment in global coordinates since I have large movements. Fro example if I release X-rotation, in the middle of the analysis X axis will be between original X and Y axes.
Question:
I am pretty sure that (('Preprocessor'/'coupling/ceqn'/'coupleDOFs')) works in global coordinate system.
When I am checking the results of the analysis (and also the manual) of the following joint elements
Revolute Joint (combin7)).
http: //www.kxca d.net/ansy s/ANSYS/an syshelp/th y_el7.html
and
The MPC-184 general joint
htt p://www.kx cad.net/an sys/ANSYS/ ansyshelp/ Hlp_E_MPC1 84gen.html
It seems that the response is in global coordinate system. How I can release moment in local coordinate system?
It seems to be a very simple answer but it is getting the hell out of me.
Again,
Thanks for your help and time in advance
Question:
http:
and
htt
Again,
