1 1/4 Cr - 1/2Mo YIELD STRENGTH
I am trying to design a TEMA BEM fixed tubesheet exchanger per ASME Sec. VIII, Div.1 with the following criteria:
Design Temp. = 1150°F
Metallurgy = 1 1/4Cr - 1/2Mo [plate (SA-387-11 Cls. 2), tubes (SA-213-T11), & Forgings (SA-182-F11 Cls 2)]
The problem I am running into is trying to interpret ASME Sec. II part D, Table Y-1. Although the material is allowed up to 1200°F, yield stresses are only listed up to 1000°F. However, I need the yield strength of the tubes, tubesheets, and shell cyl. at 1150°F to complete the UHX tubesheet calculations.
How can I find the values for yield strength at 1150°F? Does the code mention how to procede and if so where is it referenced?
Your help is greatly appreciated.
RE: 1 1/4 Cr - 1/2Mo YIELD STRENGTH
Mike
Allowable stress around 1,900 at your design temperature? Save yourself and your customer some time and take a look at another material.
347/347H comes to mind.
-TJ Orlowski
Another teeny tiny point....
A TEMA BEM for 1100+ degrees F ???/? I don't think so....
TEMA BEM is good to a maximum of ~ 300F
Aside from your client's poor choice of materials, he has a very poor choice of HX design.
Ya, ya I know.....you are running out of time and you have to bid the spec.....your boss is an MBA...
From your reply it would appear that you have come across the same "numpties" out there with MBA's. It's a pity they have the ultimate say in decision making as they tend to get it wrong on the majority of times.
But anyhow, I remember seeing the fixed plate design dwgs for the clinch river liquid sodium HX ( never commissioned), and as I recall, the tubes were twisted, en masse, to allow some flexibility for thermal expansion, shell vs tubes, during transients. Exactly how is your design going to accomodate differential expansion during transients?
A beter design would be similar to "header type" heaters, with tubeside fluid distributed / accumulated in internal headers, and the tubes able to move slightly relative to each other , also add thermal sleeves at the header to shell connection. Tubing would be T23 or T91/92, but if T23 tubes are used, the tube stub at the header would need to be another alloy ( non bainitic) if teh heder wall thickness was greater than 1" .
Mike
Its not all bad with MBAs. As a failure analyst I thank them daily for my job security.
careful now- it would be an MBA who would decide to outsource your job overseas.
