ChemCad Crude Distillation Unit
Im simulating a crude unit with heat exchanger network using chemcad. Can we actually extract the sub-stream from the crude column? For the purpose of accurate heat integration, I need to extract i.e. the pumparound stream from the column to integrate with the heat exchanger, however as far as I had been using it, I still cant find a way to bring out the sub-stream from the column.
Another question is how do we customize the column itself ? let's say I had 3 side stripper, 4 P/A and partial condenser, the column available either has 1 less side stripper or 1 less P/A or total condenser.
Thanks in advance.
Wei
RE: ChemCad Crude Distillation Unit
there is a forum under engineering computer programs where this question fits better
