Controlling Note Text Height
Hi everybody, is it possible to control the text height of a note, used for engraving within manufacturing, by expression. This is meant for the programmers to make it more aesy to change the text-height, and the surrounding text-slot by a single expression value.
Thanks in advance, Bert
RE: Controlling Note Text Height
For instance if the text needs to be .25" high then that number would be used as the scale ratio as well as the text height.
