How to abort a command which got initiated accidently in NX
Hi All,
NX6 question.. If I initiate a command and execute it, but I want to abort it, whats the best way.. Interrupt process >> Stop button is greyed out..
I used Ctrl+Shift+L , does not work in NX6..
Is there anyway I can abort the command when its getting executed?
RE: How to abort a command which got initiated accidently in NX
So the practice now is to provide, when it's safe, an explicit a 'Work in Progress' dialog with at 'Stop' button. Only when you see this dialog is it safe to 'abort' an NX operation. There is not other way except to kill the NX process itself, but then you will lose your current work.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
