Saving a deformed Body - unreliable - error message
Whenever I try to save a deformed body, I (95% of the time) get a message that says "Unable to sew faces together. Creation of deformed body failed." after what seems like an eternity to produce.
I need to save the deformed body because the customer requires some surface modeling to the deformed shape (flattening an expanded cylinder).
I have searched high and low for a solution to this problem, but whenever it is posted there seems to be a limited response. Please reply if you have any helpful tips. Thanks.
- Greenwald
- Greenwald
RE: Saving a deformed Body - unreliable - error message
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
"Node news is good news."
