Sheet metal bend
Sheet metal bend
Hello, i would like to bend that model so it will look like model will end up nice, by the blue line. Can anyone help me? Thank you.
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Sheet metal bend
weevoe
Apple your method won`t work because radius differs here, in the left part from the right part, and weevoe, if i try jog i receive an error.
What is the error you receive when using the Jog method?
You are probably receiving that error message because you have no gap between the overlapping faces. A tiny gap must exist or the model will attempt to merge the legs.
on my part file, in the feature tree:
expand base-flange1
right click baseflange1
edit feature
uncheck use default radius
enter desired radius
click green checkmark
repeat for baseflange2
