Steel Culvert, Collar Beam Design
Can anyone recommend any guidance on the design of collar beams for corrugated steel culverts. I need to design these beams to stiffen the cut ends of the culvert. I think the beam needs to be designed as a concrete compression ring.
Kieran
RE: Steel Culvert, Collar Beam Design
Kieran
http://w
Thanks for your help ishvaaag. I will look into the design software. I also found the UK document Design Manual For Roads & Bridges BD12/01 Design of Corrugated Steel Buried Structures.
Kieran
