Creating Component Patterns Within The Assembly Environment
Using Catia V5R18;
Is there a way to pattern a component in an assembly environment without using the "Reusing a Part Design Pattern" from another component?
Any response will be greatly appreciated!
RE: Creating Component Patterns Within The Assembly Environment
You can use the Fast Multi instantiation or the Define multi instantiation button in Assembly design. These 2 commands do not keep history or create constraints like the Assembly reuse pattern command.
Derek
Certified SolidWorks Professional
