Text in modeling/drafting
please look at the attached picture. What option should be switched on/of to have correct view in drafting?
NX7.0.1.7 mp2
win xp 32bit
NX7.0.1.7 mp2
win xp 32bit
RE: Text in modeling/drafting
1. Put the modelling text onto a seperate layer and use the "VISIBLE IN VIEW" drafting command.
2. Use the "VIEW DEPENDENT EDIT" option and simply delete the text from the drafting view.
I personally use the "VISIBLE IN VIEW" command all the time to control what shows on my drawings.
J
NX 6.0.5.3
Model the text into the solid body and you won't have this issue.
Tim Flater
Senior Designer
Enkei America, Inc.
www.enkei.com
Some people are like slinkies....they don't really have a purpose, but they still bring a smile to your face when you push them down the stairs.
John R. Baker, P.E.
Product 'Evangelist'
Product Design Solutions
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
RMB the View ( or double click) Style... - Hidden Lines - Include Model Curves ???
It should not need any Solid / Surface type data to work.
It might take a little extra time to process if the model is large / complex but apart from that it should do the trick.
Tomas
I use method mr. J.Baker offered : extrude text with 0 length and place text curves in other layer.
If the text is created as a "Note" in Drafting it doesn't work.
If the text is created as "Insert - Curve - text" in Modeling, it does work.
The text in the image looks like a Note.
Tomas
Look at the attached. It seems that system hides only whole symbol, and cannot hide part of it (red circles in the picture)
But when i move the text such that only part of the character should be visibe NX either keeps the entire character or erases the entire character.
