Anchor Bolt Sizing for Rotating Process Equipment
Can someone recommend some relevant codes (AISC) or references on the topic of anchor bolt (expansion or epoxy) sizing for rotating process equipment (pumps, blowers, compressors).
Any quick & dirty estimating techniques would also be appreciated.
RE: Anchor Bolt Sizing for Rotating Process Equipment
The code states that use of this table is not to be used for seismic loads so it may work with your situation. Look up "anchor bolts" in the IBC index. This would probably be the 2003 or 2006 IBC.
anyway, dont forget to use double-nut. it's standard for vibrating equipment.
