ANSYS - Static Analysis with Constant and Varying Loads
I have a structure with constant and varying loads applied on it. What is the good approach for a "static analysis" in ANSYS? I think first I have to prestress the components with constant load and then apply the varying load by keeping the prestress data... Am I right? Could you provide me with details on how to do this?
Thanks.
Tadeh
Thanks.
Tadeh
Tadeh Zirakian
Ph.D. Student in Structural and Earthquake Engineering
University of California, Los Angeles
RE: ANSYS - Static Analysis with Constant and Varying Loads
but you'd be missing the dynamic interaction between the structure and the load (tacoma narrows bridge for example), so you might want to do a dynamic analysis.
Tadeh Zirakian
take different time slices ... the varying loads will be different at the different times ...
loadcase 1 ... time = 1sec
subloadcase 1 ... time dependent loads
loads ...
subloadcase 2 ... teimindependent loads
loads ...
loadcase 2 ... time = 10sec
and so on ...
