log structure foundation design
The structure is 35 x 45 3 sided with one 45ft open wall. the corners will have 18-24in post and the walls will be stacked logs. the ground is made up of mostly rock. everything i have read so far says that i need the first row of logs 12-24in above grade. I was planning previously planning on concrete piers with rebar holding the first row of logs down. the location is ne oklahoma frost line is very shallow.
My personal experience is in metal finishing and mechanical design. I dont have industrial experience for rules of thumb in the building industry and need some help.
How do i go about determining the number of piers and spacing for this type of structure.
RE: log structure foundation design
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
You now have to look how all the loads, gravity, snow, wind, etc will be transferred from the structure to the footing to the ground.
And one other thing - log structures shrink - A LOT and this must be considered.
Get some local experienced help.
From my experience and actual construction, there are many things needed to keep walls vertical, not bowed, treated against insects, rot and birds who like to peck into the wood looking for insects, etc. How about electrical wiring in the walls? Insurance? Windows? Replacing rotted logs is very difficult.
The height of wood above ground usually is to be according to local codes for termite control.
If this is to be a permanent building, that you don't want it to rot away, I'd not go for the cheapest wood treatment, since they usually are good for only very few years.
I'd at least get a contractor on board to get the design right and the initial construction. Once underway, you can then get a good start. It's hard to fix a log structure later.
Hey, maybe a different form of building material? I'd never live in a log cabin again. Too much maintenance.
I wasnt thinking of logs as a foundation but rather that i would have concrete piers up to 24in above grade and begin the first course of logs there.
yes i am also looking for a local expert in the area while in the mean time i am trying to gain as much knowledge on this myself.
I have in the mean time found the snow load and weight of the structure. I am looking for the method of applying this to foundation size. looking to see what the variable is that must be overbuilt into the foundation. in order to appropriately space size and control the make up of the piers
Built in place is usually around $10 - $12 per square foot. +/-
If you still want a log structure - just google it. There are plenty of sites and some have some pretty good details. Or find a book on log construction.
If you plan on the logs holding the vertical load from the roof trusses then you don't want the vertical columns in the corners because the horizontal logs and the vertical log columns will have a lot different settling and shrinkage.
If you will be using someone to help you design the structure so it doesn't come falling down or have a lot of shirinkage and settling problems, you need to sit down with them and discuss the method they are familiar with before you worry about the foundation.
There are many log building styles and each has it's good and bad points. When you mix them you get a whole lot of problems.
