Note Font Size
Note Font Size
When creating a note, how can I control or change the font size?
Such as if I have, View A-A, want to make the 'A-A' bigger.
RE: Note Font Size
RE: Note Font Size
When I do this, the whole note changes font size. I only want the 'A-A' to get 2 x's larger.
At the moment, I do not see this option, unless I separate notes, which I don't want to do either.
RE: Note Font Size
If you break existing notes up into short strings you can apply formatting to the individual pieces.
{1:&view_name}{2: &det_scale} is a parametric note where the view name and the view scale can be set with different text styles. You can edit any note and put in the curly braces, number & colon to break it up for formatting.
RE: Note Font Size
I am not finding Drawing Option area or I don't seem to have a "Drawing Option" to go to in my menu drop downs.
If using this: {1:&view_name}{2: &det_scale}, where does it go & where do I designate the desired view callout name?
I added to the Text Box area & it didn't do anything for me.
RE: Note Font Size
The note {1:&view_name}{2: &det_scale} is one Pro/E makes when you create a detailed view.
