Welder Code Qualifications
Can someone refer me to the welders qualification code.  I am researching if welding to a vertical pressure vessel support leg requires special qualification, procedure and inspection if the portion of the leg is not contacting or within  some predetermined length from the pressure components.  Are the legs considered part of the pressure welding code zone?  Can you weld to legs without an alteration or rerating?
Bonkers
RE: Welder Code Qualifications
By what you describe the support leg itself is not considered part of the pressure boundary, or does not contain pressure.
Now, should you have a qualified welding procedure, welder, and NDT for weld repair of the support leg? ABSOLUTELY.
Yes, I plan to stiffen the support by welding cross brace members to the support legs.  I could not find the pressure vessel limitations of the pressure vs. nonpressure zone.  I want to stay away from the leg/vessel attachment weld.  Is there a section in ASME BPVC Sect. VIII Div. 1 to support this?
Thanks for your reply!
Bonkers
Basically, ASME B&PV Code, Section VIII deals with new construction design rules, which consist of pressure boundary design rules and non-pressure part attachment weld requirements to the pressure boundary.
Since you are welding a non-pressure part material to an existing non-pressure part material, this falls outside of Section VIII construction code.
ASME Section IX provides detailed information on welder and welding procedrue specification qualification.
Bonkers,
I feel like that most of the time.
Back to your question tho, you do not need any special code of construction or repair code to add X-bracing to supports.
However the additional bracing should be considered in calcs and the welder should be currently qualified as per Sec IX.
Assuming the pv is located at a mill or plantsite, that entity would have jurisdiction and most mill have their own welding standards.
Hope this helps,
Robert
Thanks to all responders!  You have answered my question and given me direction and support!
Thanks again, I'm going.....
Bonkers
Please, see AWS D1.1 Structural Welding Code- steel
r6155
