Recovered hot water into steam generation
I have pressurized (~360 psig) hot (~280C) water which I have captured in my process. I am looking to generate steam with it (~290 psig). Can someone recommend me a company that deals with this kind one off systems.
I am apologies if this is repeating thread. Something seems didn't worked out when I posted a first time.
Thank you.
Thank you.
I_mak
RE: Recovered hot water into steam generation
I_mak
Or do you want to use a heat exchanger to generate steam. I know of one application where steam has been generated by using hot water, so it is a possibility, but again, as you want to generate steam at relatively high pressure you will be limited how much you will get.
Are there any other ways in which you could use the energy? What sort of industry are you in?
