PED Classification of Jackets
Hi
I'm trying to complete PED classification for a pressure vessel with limpet coil. I cant decide what way I should analysis the jacket, i.e is it a vessel or a pipe?
Any ideas?
Any ideas?
RE: PED Classification of Jackets
The jacketed vessel is a pressure vessel, designed per the pressure vessel code (I assume you weld the pipe/halfpipe to the exterior of the shell, don't you?). That is, the inner vessel is designed for internal pressure and additionally to external pressure exerted by the coil.
Cheers,
gr2vessels
Yes it is a pressure vessel dsigned to EN 13445 3/-1 barg (160/-20 Dec C). The limpet coil (10/-1 barg, 160/-20 Deg C, capacity 552L) is welded to the exterior of the pressure vessel shell.
Vessel is a group 1 fluid.
Jacket is a group 2 fluid.
So what PED group should the jacket be?
Tks
The groups you mention stay two different groups.
Greetings
