A387 Grade 5 supplier - North America
I am seeking a supplier for a very small quantity of 5-chrome plate, to be used for machining corrosion test coupons.  Would anyone be able to point me to a North American supplier?  I have been searching in the web, with very limited success.  Everything seems to come up as UK or India.
RE: A387 Grade 5 supplier - North America
You will be hard pressed to find a supplier in North America for a small quantity of this material.  Your best bet would be to find a manufacturer that uses larger quantities of this plate and see if they would be willing to sell you some drop or excess material.
If the plate only serves a corrosion test purpose, what's wrong with getting it from the countries you listed?  A simple chemistry check will adequately verify the material you have procured.
As posted above it's hard to get a few fasteners except at Big Box Store.
You might want to ALSPI for your corrosion test coupons.
http://www.alspi.com/alloys.htm
We have used them to supply all our corrosion test coupons since they started.  We used their samples for laboratory and on-stream testing.
Try American Alloy in Houston, Texas
www.aasteel.com
713-462-8081
