Use of API 510 and API 579 to Supersede UG-45
An existing, in-service vessel was originally constructed and stamped to ASME Section VIII, Division 1. Various nozzles do not meet the UG-45 requirements in effect at time of fabrication nor the same requirements which are currently in Table UG-45. The vessel now falls under the jurisdiction of API 510, which states that most of the technical requirements of the ASME Code can be applied to existing vessels.
Under the auspices of API 510 is it permissible to supersede the requirements of Table UG-45 using API 579/ASME FFS-1, Fitness for Service, and ultimately finite element analysis? Stated another way, is it permissible to supersede Table UG-45 by FEA for a vessel operated, inspected, and, maintained under API 510?
RE: Use of API 510 and API 579 to Supersede UG-45
Subject: ASME FFS-1
see ASME FITNESS FOR SERVICES API 579-1/ASME-FFS-1 2007; API 579-2/ASME-FFS-2
2009
http:
example 1 slide: 25, 26, 27, 28,
31, 32, 33, 34, 35, 36
