Online chlorine analyzer
Hello everyone,
Is there on the market an online water chlorine analyzer that could be installed directly in a piping system (something like a pH probe) for an industrial application.
We would like to avoid the need to run a sampling water line toward a test unit.
Thanks in advance for your help.
RE: Online chlorine analyzer
Also check Enress + Hauser, I've had good success with their online chlorine analyzers.
Good on ya,
Goober Dave
Any ORP probe will work but, they are sensitive to:
fouling, water velocity near the probe, pH, local EMF, and electrolyte age.
So if you can calibrate adjustments for all these factors you may have a reliable instrument.
These are some of the reasons why these probes are installed in a sample stream and not in the main pipe.
Hydrae
