Transfomer vector group
Any advantage in choing which group to use
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Transfomer vector group
Marmite
Do you want a Delta,Wye, Zigzag or independant winding for the primary and secondary side of your transformer?
the second question is what phase angle do you want between the windings? that is the number after the Dy or Dyn tells you how much the LV lags the HV side 1 is 30° 2 is 60° 11 is 330° or a 30°lead.
Different applications benfit from different vector groups
Are you connecting to the utility? they will probably specify what you need.
Is it a plant distribution transformer - what are the other thransforems in the plant?
Lots of good information out there on the internet, that is worth looking up. 10 minutes on Google will probably give you enough information. Or ask your supplier for a tutorial or technical guide. ABB have a good transformer guide book .
Its realy depend on your purpose.
But, one thing you should be consider is price.
Some of special transformer / optional transformer is expensive.
