User element subroutine VUEL in Fortran 90
Dear Sir/Madam:
I am developing an element user subroutine (VUEL).
I have a Windows 7, 64 bit machine, and I am compiling using Intel Fortran 2011.
I am testing the possibility to run a VUEL with ABAQUS using a example available from the ABAQUS documentation. It is called: vuel_truss.for, and it is written in Fortran 77. The input file is called vuel_truss_3d_1el.inp. When I use these two files everything works in both cases, when I generate the object file and then I run ABAQUS, or when I just run the fortran subroutine from ABAQUS. Now I am trying to convert vuel_truss.for in Fortran 90, because I want to write mi VUEL in Fortran 90. I am able to generate the object file specifing that I need the "-free" format for the compilation using the command: "ifort -free vuel_truss.for". When I try to run the analysis from the object file I have the error:
C:\Users\oaklandmmi2\Desktop\Andrea\Research & Development\LDPM for ABAQUS\MMI\2
011-01-14 vuel_truss_3d_1el from ifort\Fortran 90\for>abq6101 interactive job=te
st input=vuel_truss_3d_1el user=vuel_truss.obj
Abaqus JOB test
Abaqus 6.10-1
Begin Linking Single Precision Abaqus/Explicit User Subroutines
2/22/2011 9:35:24 PM
   Creating library explicitU.lib and object explicitU.exp
End Linking Single Precision Abaqus/Explicit User Subroutines
Begin Linking Single Precision Abaqus/Package User Subroutines
End Linking Single Precision Abaqus/Package User Subroutines
Begin Analysis Input File Processor
Run pre.exe
Abaqus License Manager checked out the following licenses:
Abaqus/Explicit checked out 5 tokens.
<29 out of 40 licenses remain available>.
2/22/2011 9:35:27 PM
End Analysis Input File Processor
Begin Abaqus/Explicit Packager
Run package.exe
Abaqus/Explicit 6.10-1                           DATE 22-Feb-2011  TIME 21:35:28
***ERROR: There is no element available in the model to control the stable
          time increment for Step 1. Please add a deformable element to
          control the stable time increment. Alternatively, you can use DIRECT
          TIME INCREMENTATION to perform the analysis at a user specified time
          increment.
2/22/2011 9:35:29 PM
Abaqus Error: Abaqus/Explicit Packager exited with an error - Please see the
status file for possible error messages if the file exists.
Abaqus/Analysis exited with errors
If I run the vuel_truss.for file I have a bunch of compiling errors if I do not add the flag '-free' in the compile fortran section:
compile_fortran=['ifort', '/c','/DABQ_WIN86_64', '-free',
                 '/recursive', '/Qauto-scalar', '/QxW', '/nologo', '/Od', '/include:%I']
what I observe also is that there is some difference in the dimension of the two object files generated from the Fortran 77 and 90 files.
To summarize, I would like to know how to make work Fortran 90 subroutine with ABAQUS.
Best,
Andrea.
See file here:
*Heading
 A one element truss along global x-axis modeled using user defined element.
 The element is coded in "vuel_truss.for".
 Geometrically Nonlinear, No mass scaling
*Parameter
 CsArea=1.002
 YoungsMod=2.1E7
 PoissonRatio=0.0
 Density=7200.0
*Node
 1, 0.0, 0.0, 0.0
 2, 1.0, 0.0, 0.0
*Nset, Nset=AllNodes
 1,2
*Nset, Nset=LeftNode
 1,
*nset, nset=qa_test_leftnode
 1,
*Nset, Nset=RightNode
 2,
*nset, nset=qa_test_rightnode
 2,
*User Element, Nodes=2, Type=VU2, Properties=4, Coordinates=3, Variables=2
 1, 2, 3
*Element, Type=VU2, Elset=AllElements
 1, 1, 2
*Uel Property, Elset=AllElements
 <CsArea>, <YoungsMod>, <PoissonRatio>, <Density>
*Boundary
 LeftNode, 1, 3, 0.0
 RightNode, 2, 3, 0.0
*Amplitude, Name=LoadAmp, Definition=Smooth Step
 0.0, 0.0, 1.0, 1.0
*Step,Nlgeom=Yes
*Dynamic, Explicit, Element
 , 1.0
*Bulk Viscosity
 0.0, 0.0
*Cload, Amplitude=LoadAmp
 RightNode, 1, 1.0e6
*Output, Field, Var=Preselect
*Output, History, Freq=1
*Node Output, Nset=AllNodes
 U1, V1, A1, RF1
*node output, nset=qa_test_leftnode
 RF1,
*node output, nset=qa_test_rightnode
 u1,
*Energy Output
*End Step
vuel_truss.for (in Fortran 90)
! user element for truss along the X global axis
subroutine vuel( nblock, &
                ! to be defined
                rhs,amass,dtimeStable, &
                svars,nsvars, &
                energy, &
                nnode,ndofel,props,nprops, &
                jprops,njprops,coords,ncrd, &
                u,du,v,a, &
                jtype,jelem, &
                time,period,dtimeCur,dtimePrev,kstep,kinc,lflags, &
                dMassScaleFactor, &
                predef,npredef,jdltyp,adlmag )
include 'vaba_param_dp.inc'
parameter ( zero = 0.d0, half = 0.5d0, one = 1.d0, two=2.d0 )
! operation code
parameter ( jMassCalc            = 1, &
            jIntForceAndDtStable = 2, &
            jExternForce         = 3 )
! flags
parameter ( iProcedure = 1, &
            iNlgeom    = 2, &
            iOpCode    = 3, &
            nFlags     = 3)
! time
parameter (iStepTime  = 1, &
           iTotalTime = 2, &
           nTime      = 2 )
! procedure flags
parameter ( jDynExplicit = 17 )
! energies
parameter ( iElPd = 1, &
            iElCd = 2, &
            iElIe = 3, &
            iElTs = 4, &
            iElDd = 5, &
            iElBv = 6, &
            iElDe = 7, &
            iElHe = 8, &
            iElKe = 9, &
            iElTh = 10, &
            iElDmd = 11, &
            iElDc = 12, &
            nElEnergy = 12)
! predefined variables
parameter ( iPredValueNew = 1,  &
            iPredValueOld = 2, &
            nPred         = 2 )
! indexing in a 3-long vector
parameter (factorStable = 0.99d0)
dimension rhs( nblock,ndofel), amass(nblock,ndofel,ndofel), &
               dtimeStable(nblock), &
               svars(nblock,nsvars), energy(nblock,nElEnergy), &
               props(nprops), jprops(njprops), &
               jelem(nblock), time(nTime), lflags(nFlags), &
               coords(nblock,nnode,ncrd), u(nblock,ndofel), &
               du(nblock,ndofel), v(nblock,ndofel), a(nblock, ndofel), &
               dMassScaleFactor(nblock), &
               predef(nblock, nnode, npredef, nPred), adlmag(nblock)
!     VUEL subroutine for a truss element along the global X-axis only
!     superimposed with rotations at both ends
!     Limitations:
!       It will not work if motions along another direction other than X
!       Nodes must be noncoincident
!     Notes:
!        Define only nonzero entries; the arrays to be defined have
!        been zeroed out just before this call
!        for jInternForceOnly, one can use state vars to
!        compute initial forces at time zero (prestress)
if (jtype .eq. 2 .and. lflags(iProcedure).eq.jDynExplicit) then
area0 = props(1)
eMod  = props(2)
anu   = props(3)
rho   = props(4)
eDampTra    = zero
amassFact0  = half*area0*rho
    if ( lflags(iOpCode).eq.jMassCalc ) then
        do kblock = 1, nblock
            ! use original distance to compute mass
            alenX0 = (coords(kblock,2,1) - coords(kblock,1,1))
            alenY0 = (coords(kblock,2,2) - coords(kblock,1,2))
            alenZ0 = (coords(kblock,2,3) - coords(kblock,1,3))
            alen0 = sqrt(alenX0*alenX0 + alenY0*alenY0 +alenZ0*alenZ0)
            am0   = amassFact0*alen0
            amass(kblock,1,1) = am0
            amass(kblock,2,2) = am0
            amass(kblock,3,3) = am0
            amass(kblock,4,4) = am0
            amass(kblock,5,5) = am0
            amass(kblock,6,6) = am0
        end do
    else if ( lflags(iOpCode) .eq. jIntForceAndDtStable) then
            vol0 = area0*alen0
            amElem0 = two*amassFact0*alen0
            alenX=alenX0+(u(kblock,4)-u(kblock,1))
            alenY=alenY0+(u(kblock,5)-u(kblock,2))
            alenZ=alenZ0+(u(kblock,6)-u(kblock,3))
            alen = sqrt(alenX*alenX + alenY*alenY + alenZ*alenZ)
            area   = vol0/alen
            ak     = area*eMod/alen
            ! undamped stable time increment for translations
            dtTrialTransl = sqrt(amElem0/ak)
            ! damped stable time increment; since eDampTra=0, the
            ! stable time increment does not change because of damping
            critDampTransl = two*sqrt(amElem0*ak)
            csiTra = eDampTra/critDampTransl
            factDamp = sqrt(one+csiTra*csiTra) - csiTra
            dtTrialTransl = dtTrialTransl*factDamp*factorStable
            dtimeStable(kblock) = dtTrialTransl
            ! force = E * logarithmic strain *current area
            strainLog = log(alen/alen0)
            fElasTra = eMod*strainLog*area
            forceTra = fElasTra
            ! assemble internal load in RHS
            rhs(kblock,1) = -forceTra
            rhs(kblock,4) =  forceTra
            ! internal energy calculation
            alenOld  = svars(kblock,1)
            fElasTraOld = svars(kblock,2)
            energy(kblock, iElIe) = energy(kblock, iElIe) + half*(fElasTra+fElasTraOld)*(alen - alenOld)
            ! update state variables
            svars(kblock,1) = alen
            svars(kblock,2) = fElasTra
        end do
    else if ( lflags(iOpCode) .eq. jExternForce) then
        if (jdltyp.eq.123) then
                  rhs(kblock,4) = adlmag(kblock)
            end do
        end if
    end if
end if
return
end
