Wood Supporting Concrete
This subject has been discussed here before, probably beating a dead horse. Nevertheless...
Have a possible project where the client wants to build an earth home on a rock bench. He wants to use PT planks for the roof with sod over, all supported by Glulam Beams. I believe the code states that concrete cannot be supported by wood except under certain situations, such as lateral, but I am wondering on the logic here.
Asside from the huge size of beam that would be required, I am wondering if the problem is inherently in the wood to concrete contact, which could be alleviated with a metal cover bracket between the two.
Any thoughts here?
Any thoughts here?
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
RE: Wood Supporting Concrete
I don't know what your code states, but our code permits concrete to be supported on wood provided the fire rating is adequate for the occupancy affected.
BA
Both codes allowed lintels to be installed on wood members and support brick. What's the diff??
I just haven't had much reason to violate the rule - if it is still in the code.
Mike McCann
MMC Engineering
Motto: KISS
Brad
