Allowable Point Bearing Capacity of Piles Resting on Rock
I am involved in a design for an H pile which is to support a 90 ton vertical load. The pile will be driven down to rock. The skin friction of the pile has been calculated and has been determined to be relatively small compared to the point bearing capacity. Two methods were used to calculate the point bearing capacity of the pile resting on rock and were found to be extremely different. My question is has any had experience using the following equation for Point Bearing Capacity of Piles Resting on Rock Qp=(qsubu*Nsubphi + 1)*Ap from Goodman 1980. This referenced formula was taken from Principles of Foundation Engineering 5E by Braja M. Das. Is this the correct formula to be using when trying to calculate the capacity? We are trying to compare our results to the CivilTech Software program which uses the following equation Qp= Ap*(Nsubq*Ssubv + Nsubc*C) to calculate the capacity of piles on rock.
RE: Allowable Point Bearing Capacity of Piles Resting on Rock
