Encasing DIP in Concrete, Bad Idea?
I've heard mixed opinions about having a cast-in-place concrete encasement around DIP, say for water systems. I've seen it done many times, but I've heard that some people have concern over the concrete being in direct contact with the DIP. What is the concern, and is it valid? Would a possible fix be to put Poly-wrap around the pipe before casting the concrete? Are there concerns regarding the joints, i.e. concrete getting at the rubber gaskets? Maybe another reason to use the poly-wrap before pouring the conrete? Your thoughts are much appreciated.
RE: Encasing DIP in Concrete, Bad Idea?
Chlorides from road salt are probably more of a concern for corrosion to ductile iron than concrete.
