Import Step file(assembly)
In Wildfire 4, When I am opening or importing assembly step file into pro/e
I having Error toolbox, after I select the done>return it's continu to import until the next Error. and again I select Done>return. filnaly the file is opened.
If I will do it In wildfire 2 the file is opened without any errors.
Is this something with the config.pro that I have set.
Elkanj
Elkanj
