APDL/Modeling/BC/Saving/Database/
Hello everybody,
I have a very basic question. After doing my simulation, I am not able to get back my data/see my BC/Results.
I will describe what I am doing step by step. Maybe somebody can tell me what I am skipping.
FIRST STEP
1)I opened the product launcher and type XX as jobname.
2)I click RUN. A new, empty file is opened.
3)I create geometry
4)I select element type
5)I enter material properties
6)I enter loads (I am applying thermal loads but this is not relevant I think)
7)I go to SOLVE the problem.
8)I check my results, everything is fine.
9)I save my database by SAVE_DB, and click exit and choose SAVE EVERYTHING...
10)I close my product launcher
Now, I want to check my model.
SECOND STEP
1)Open product launcher
2)I select the XX.db filename, than say RUN
3)When APDL is opened, I click RESUME_DB and I see my model on my screen.
4)When I click Material Properties,
-1)I am not able to see the TEMPERATURE UNIT that I specified!
-2)My material model stays there.
5)I want to check my TEMPERATURE (which was defined previously), and when I want to delete it, it says "this function requires defined areas. No areas are currently defined".
6)When I SOLVE the problem again, it solves but there is no results because there is no boundary conditions actually.
Could somebody help me about what I am doing wrong?
FIRST STEP
3)I create geometry
SECOND STEP
Best Regards,
Sartor
RE: APDL/Modeling/BC/Saving/Database/
I'm not following what you're trying to do when you delete your temperature. Are you trying to change the boundary condition?
Perhaps some screenshots would be useful.
RESUME_DB and READ_RESULTS...
now it is working.
Thanks a lot.
Best Regards,
Sartor
